1 members (GRNHydra),
161
0
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Ok. So I've got a negative ground system. Tell me if this should work.
1. Batt to relay
2. Single wire off the steering column to relay
3. Wire from relay to horn.
4. Horn grounded to frame.
I tried this and it doesn't work. If I run the switch wire on the relay to the positive post, I can hear the relay click. Horn only sounds if I cross the switch wire and the negative from the battery directly the positive post.
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Oct 2016 Posts: 496 Shop Shark | | Shop Shark Joined: Oct 2016 Posts: 496 | Klaxon oooogha.
I figured it out though. The relay chassis needs to be grounded. Works like a champ now!
