7 members (NJC, baldeagle, Gray_Ghost, Peggy M, Wickedbass, Charles in CA, cmayna), 77 guests, and 7 robots.
Topics128,018
Posts1,055,342
Members48,419
#127215 07/10/2007 11:05 AM
Just got a cab mount kit (rubber parts) from Classic Parts and was wondering what the tube shaped parts were for. There are 8 of them, about 3/4" diameter and about an inch long with a shoulder on one end. Just wondering what to use these for.
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#127216 07/10/2007 11:19 AM
should be for the rear mounts. they go inside the shackles. hope this helped.......dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
#127217 07/10/2007 1:33 PM
Quote
That is correct for the late model 49 truck. The early model 49 had a center cab mount at the rear. Which one do you have?
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#127218 07/11/2007 12:03 AM
I've got a late '49. Put it together on an extremely tight budget (ex had a coniption every time I wanted to spend a dime on it) so I didn't put mount kit in. Redoing it now so thought I might as well do it right.
#127219 07/11/2007 12:13 PM
ODSS President
ODSS President
I just did the job for the late '49 this past weekend. What I did was to use a floor jack with a couple of 2 foot 2x6's stacked on top to slightly lift the body of the cab up from the frame...only about an inch or so. I then removed the entire bracket, cleaned, then lined the inside of the bracket with silicone caulk to protect the rubber parts in the future from dry rot-water infiltration.
The top two bolts are tricky with the seat and gas tank in the truck as mine were but it can be done. I held the upper bracket in place with a tapered punch in one hole and started a bolt in the other. Once the two upper bolts were in I found I had to lift the cab one or two more inches to help allign the frame bolts. If you're in no hurry the job's a breeze.
Replace your front cab mounts as well, you'll be shocked at how well the truck rides!
~ Cosmo
1949 Chevy Half Ton
#127220 07/11/2007 9:37 PM
Cosmo,
Thanx for the info. I got the entire mount kit from Classic Parts. I bought a '50 1/2 ton mainly for the frame as it already has a Camaro clip and rear end in it. I'll be transfering my entire body to that frame, so I'll put the mount kit in when I do that. Thanx again.
#127221 07/23/2007 3:31 AM
1 Offline
Reguarding cab mounts has any one found the right mounts for a 48 cab? Those cabs have the shackle set up int the center of the back but are suposed to have two tall rubber stoppers on the outer corners as well. Just the center shackle is not enough. I replace those a couple of years ago and just sitting in the shop it sags a little. I just can't find a complete kit that has the outer mounts.
