My '40 just went out for paint but the last minute work included digging out the rotted wood filler strips under the floor sill on both side of the cab. The pieces I got out are no good for a pattern even they were so bad. Does any one have a pattern they might like to pass along. They seen to be around 20" long, 2.75" wide and 1" thick but have a filler strip under the front 3-4" inches.......this is a Canadian truck from Saskatchewan and apparently the wood pieces are bigger than the ones used in the US trucks. I even have an email into the Reynolds museum in Wetaskawin Alberta where they have a restored 1940 Chev truck. Any help would be appreciated. Thanks
