3 members (TooMany2count, 32Fordpuchoptop, Hotrod Lincoln), 92 guests, and 3 robots.
Topics128,141
Posts1,056,485
Members48,441
#1271456 07/06/2018 11:08 PM
Looking for a source to get a replacement spring for my parking brake. It goes around the shaft of the parking brake pedal. The release rod pulls flat bar to move the spring to release the brake. I suspect the 65-year-old spring has been compressed too many times as the brake will not hold.
Thanks Denis
Used to drive Subs, prefer old rides
1952 chevy 3100, 5 window
Jim carter has that as part #me146 1936-1950--make sure the rod that goes thru it is clean--I used scotch brite on it--Bill
I'm with Bill. That spring is indestructible as long as it isn't rusted into pieces. You have another issue going on.
Bill thanks they sent me that part and it is not the right spring. It is 6 inches long. As you can see in the picture mine is maybe an inch or so.
Carl any thoughts what else could be wrong?
When I step on parking brake pedal, the shaft goes down smoothly put the flat metal rod does not hold it depressed, my assumption was the spring was not pushing the flat metal to hold the brake pedal rod in the depressed position?
Denis
Thanks Denis
Denis--I gave you wrong number--Look at Chevs of the 40's site part #3695565--that is what I bought..Bill
Bill that's it! I need to call them, part is $6 but shipping is 16! Denis
Thanks Denis
Denis
There is a lot going on with those parking brakes to make them work right,. Can you take some pics of your parts viewed from inside the cab?
Do you have the long spring and long rod which connects to the cross bar behind the cab?
Everything needs to be hooked up for it to work properly.
Moderator, Electrical Bay
I don't believe I've seen one of these springs fail, but the whole thing will work better if you disassemble it and clean it very well (a bench grinder with a wire wheel or something).
Jon
~ Jon
