2 members (Ponchogl, Hush),
67
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | Has any body tried the newer Inner bottom Kick patch panels that are 9" tall? They look to be Black on eBay. If so, is the stamping like the originals. | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | Dave... I've tried to find the kick panels you're refering to on ebay, but couldn't find them. Is it possible to post a link showing them? I'm curious myself to see em.
Thanks, | | | | | Joined: Jul 2007 Posts: 6 New Guy | | New Guy Joined: Jul 2007 Posts: 6 | David,
I did not see them on Ebay, but I need both sides for my '64. Do you know where I can buy them? | | | | | Joined: Jul 2006 Posts: 100 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 100 | Not sure how to post link but this is the item number 120140504324. They come from Key Parts Inc. I should be getting mine to day. Im still looking for a good use pair that goes all the way up. | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | The panels for a '64 are available from Chevy Duty but they're actually designed for '67 to '72. I got mine in but I had to do some blacksmith work to make them fit. I'm going to put plastic covers over them so they didn't have to look perfect.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Jul 2007 Posts: 6 New Guy | | New Guy Joined: Jul 2007 Posts: 6 | I just spoke with the man at Key Parts, Inc. He said that the correct inner kick panels for the 1960-1966 Chevy Trucks are in production and due to be available some time this year, but he could not say when. They are listed in his 2007 parts catalog as item #0848-225 & 0848-226. I hope this helps. Thanks and God Bless! | | | | | Joined: Mar 2005 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 121 | I went the 67-72 route with my 66, or at least tried to. I wouldn't waste my money on them, there is just too much modification required to make them work. I ended up making some from scratch and will be covering them with trim panels.
Dave 66 GMC- father /son project with the "GMC KID" 36 Chevy PU- 4x4 lifetime project 64 Skylark- wife says its hers
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Originally posted by dave64: I went the 67-72 route with my 66, or at least tried to. I wouldn't waste my money on them, there is just too much modification required to make them work. I ended up making some from scratch and will be covering them with trim panels. Same experience here, need a pair right now but already have a template cut out for smithing my own, cheaper that way too. | | |
