1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1271251 07/04/2018 10:23 PM
Hi all a quick question about diff ratios. I am not sure what ratio my 42 1 1/2 ton chev truck has. It has a 4 speed manual trans, would a 2 speed diff help
I would like to get a little more highway speed.
Cheers Justin
Aus42blackout #1271259 07/04/2018 11:12 PM
No. 2 speeds axle is only slower in low. You won't get there any faster.
If you can get bigger tires like 825-20 might be the easiest option to gain a little.
J. F.
Aus42blackout #1271358 07/05/2018 11:18 PM
ok thanks
Aus42blackout #1271374 07/06/2018 1:54 AM
http://chevy.oldcarmanualproject.com/chevyresto/4670.htm
Looks like 5.43:1
Good Luck with your truck.
Professional Novice
