Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Forty9, Hotrod Lincoln, 55shaker, baldeagle, NJC), 51 guests, and 3 robots.
Topics128,005
Posts1,055,263
Members48,418
#1271186 07/04/2018 1:43 PM
Is there a difference between the 1954 gmc and the 1954 Chevy trans
I have a gmc and have a good Chevy trans. Can I put trans. In truck?
One difference would be the flywheels.
Another difference that would most likely not matter: carburetors.
Cletis, we need you (he had both transmissions).
Maybe Greg Hill knows?
What difference is the flywheel?
I think there is a difference in the flywheel mounting-bolt pattern (and, number of bolts) on a 1953 GMC H-M, compared to the later Chevrolet H-M flywheel.
If that is correct, I would guess the later GMC H-M's bolt-pattern (and, number of bolts) would also be different.
H Online: Content
The fluid coupling (no, it's not a torque converter) from the Chevy will probably interchange with the GMC transmission. If it's in good shape, that will probably solve the fitment problem when the GMC trans is bolted to the Chevy engine. Be aware that the runout between the bellhousing and the crankshaft centerline is extremely critical when the hydramatic is mated to the engine, so much so that Chevy matched engines and bellhousings at the factory on H-M equipped vehicles.
Can I put a Chevy trans. To replace the gmc trans?
