2 members (mick53, 37 GC), 151 guests, and 2 robots.
Topics128,147
Posts1,056,797
Members48,454
#1271016 07/03/2018 3:02 AM
Can someone clear up where I fall short on this turn signal install?
I’ve converted the parking lights to duel 1157s in the front. The brake lights and running lights are two separate bulbs on each side.
I understand how to wire the front and back lights.
My question is with the “hot wire” and the “red” wire in the diagram. (Picture included) Do I run the “red” wire to the brake switch and leave the other side running to the terminal “stop”?
Also, what’s the best place to land the fused power wire?
All my wiring is original except the rear brake and running lights. Fuse box. 6 volt.
Thanks Don
Can’t begin to tell you how much I hate the name Stovebolt.
No pic
Sorry for my slip up on the pic.
Don
Yes. On the stop switch
You can grab power where you want. Some people run straight to battery source, so the hazzards will work even if you have other issues.
I just went off acc on ignition
