7 members (Slick Willy, Lostbuthaulinass, Otto Skorzeny, homer52, Gib70, BC59, 1 invisible), 115 guests, and 3 robots.
Topics128,134
Posts1,056,410
Members48,441
#1267487 05/30/2018 1:08 AM
I took my 1940 3/4 ton out for a drive this weekend and on the way home I could not shift into 4th it would just grind no matter what I'd do...I was thinking it's clutch adjustment but is it odd that all the other gears shift fine. Its an unsynchronized 4 speed and I've never had this issue before....What could it be?!
I don't know. What about a rebuild.
(once I give a incorrect answer someone else will chime in)
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
It's was shopped out when I restored it....transmission shop said it looked great it just needed cleaning so they serviced it. It was a few years ago but not many miles
Crusing in the Passing Lane
Could have something gotten in the shift rail hole or blocked it?
Ed
These trans are pretty basic .
I suggest you pull the top off and inspect the shift link mechanism. Then inspect the shift forks where they slide over the gears , something is worn or broken . It should be obvious .
edit , as the other gears work fine , it cannot be clutch related .
Was there a resolution to this problem? I have a 46 3/4 ton with a 4-speed and I am trying to learn as much about it as I can.
thanks.
