0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 30 | Ok. I have removed my straight axel and then removed king pins. I never had king pins to deal with before and befor I paint steering knuckle I'm wondering if I'm wasting my time or should i look for replacements . I have new kings and bushings ready to go. As I look into knuckle where bushing and pin will go i notice severe scarring inside...will this matter as long as bushings insert correctly and king pins not loose? My one spindle looks like some one may have spun a bearing on inner bearing set as I see someone used a punch or drift and had many holes and was thinking they did this for a spun bearing at one time. Will this have ill effects if I put together with new bearings. Let me add I know nothing about this as I never have had a vehicle completely apart befor. I don't wanna waste money..i haven't had luck with finding correct replacements so far as it seems they carry drop spindles everywhere but I'm looking to keep her correct height and stock 8 lug drums in front. Thanks in advance! | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The punch marks trying to correct a loose bearing fit isn’t a good thing, I’d b hunting for a replacement spindle. The AD 3/4 ton spindle is shared with 1 ton, and the 1.5 ton (without heavy duty axle option). | | | | | Joined: Jun 2018 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 30 | Ok thanks that's what I was thinking. I will try to replace both but so far all i have found are drop spindles everywhere I look Grigg. These are not like the finding the drums are they? Or am i not looking at the right site? Visited many online sites so far a hard find new oem. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Very unlikely you find them new, if so they’ll be new old stock. They came in 3 different size trucks, so plenty of used ones.
There was a spindle bearing diameter change in the early 50’s may look that up and decide if you’re better off with the early or late version of the spindle. | | | | | Joined: Jun 2018 Posts: 30 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 30 | I'm hoping to see if I got the link setup right and to see what I'm dealing with. I don't intend on using the spindle with punch marks. Not sure if I will use either one. damaged spindles and knuckle bore holes | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The marked bores in the one spindle will probably be OK with new bushings fit and reamed. The punch marks to improve bearing fit is still questionable.
When you find a replacement front axle perhaps it has two good spindles. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | To clarify my earlier comment about different spindles for different years, note different bearing bore sizes, so different spindle sizes, from this thread https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=604816#Post604816Found the bearings in the Timken catalog. Front (original) wheel bearings for 3/4 and 1 ton Chevy.
Bearing # ---- Bore --- O.D. ----- Overall Width --- Outer cup width --- Inner cone Width- '53 to '59 B-46 ------- 1.4995 --- 3.1500 ---- 1.2360 ----------------- .8510 --------------- .9170 B-45 -------- .9058 ---- 2.2503 ---- .8000 ------------------ .6900 --------------- .6590 '46 to '52 B-26 ------- 1.4060 --- 3.1500 ---- 1.2260 ----------------- .8510 --------------- .9170 B-25 -------- .8435 ---- 2.2503 ---- .8000 -------------------.6900 --------------- .6590 | | |
