Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
8 members (Hotrod Lincoln, farmallb, Chip O, tclederman, Charles in CA, Otto Skorzeny, Stovebolt48, TooMany2count), 46 guests, and 0 robots.
Topics128,006
Posts1,055,272
Members48,418
#1270385 06/27/2018 12:19 AM
1950 chevy suburban.....
I replaced the main spring and one of my handle droops. I suspect it may be that the post on the handle is twisted. Is there any way to adjust the post on the handle?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
I took the handle off, put the square part in a vise and lifted up--works fine now--no droop---Bill
It was/is common to twist the square shaft to fix the droopy handle issue.🛠
You're also battling the wear between the shaft and the shaft hole.
Yeah, I'm going to do the vise twist tomorrow. I'm just happy I got it all timed right and operating correctly tonight.
Done....fixed....thanks!
Moderated by  ndkid275, Phak1
