5 members (fonz8261, dt235sd, klhansen, greenie-reddy, Opelika Tom), 100 guests, and 3 robots.
Topics128,078
Posts1,056,283
Members48,441
I don't know if there is such a thing, but an index for the factory assembly manual would be awfully handy. I seem to recall awhile back that there was some reference to such an index, but I can't find it.
Anyone have any info?
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
This Thread has some info also.
I scanned the indexes.
You can view them HERE
Not sure if Photobucket is viewable.
From those scanned indexes you can find the Section & Sheet number for the particular part of the truck you're looking for.
Mainly 3100 or 1/2 ton indexes
01> Sec.. 0 sheet 1.00... Model 3100 Chassis instruction index
02> Sec.. 0 sheet 1.00... Model 3000 Cab & Sheet Metal instruction index
03> Sec.. 0 sheet 1.00... Model 3000 4000 6000 Electrical & Instrument instruction index
04> Sec.. 0 sheet 4.01... Model All Cabs LD RPO 264 Unison Seat instruction index
05> Sec.. 0 sheet 13.00. Model 3000 RPO 314 Automatic Trans. instruction index
06> Sec.. 1 sheet 1.00... Model 3000 4000 6000 Cab Welding instruction index
07> Sec.. 1 sheet 2.00... Model All Cabs Seat Frame instruction index
08> Sec.. 1 sheet 3.00... Model 3100 Under Body & Dash & Toe Panel instruction index
09> Sec.. 2 sheet 1.00... Model 3100 Frame Assembly instruction index
10> Sec.. 6 sheet 1.00... Model All Engine instruction index
11> Sec.11 sheet 1.00... Model 3000 Chassis Sheet Metal instruction index
12> Sec.14 sheet 1.00... Model 3000 Cab & Sheet Metal Sealing instruction index
Works for me. Thanks, jorb
Mainly 1954/55st 3100 or 1/2 ton indexes
well, it worked once - now I get hung-up in Photobucket bs-land
no, it might be working again?
Last edited by tclederman; 06/28/2018 1:53 AM. Reason: direct link worked once, but only once - I added another
"Photobucket bs-land"
Couldn't say it any better!
Hey guys, this may be a stupid question. In the manual a lot of the diagrams reference "Model 3000". What is that, and how does it differ from a 3100? Is it inclusive of all 3000's, ie 3100/3600/3800 etc? I'm trying to separate out all that doesn't pertain to the 3100 I'm working on. Thanks!
Matt M.
'49 Chevy 3100 5 Window (Project, started Feb 2019)
That is correct, mattmus4357
3000 would indicate any 3XXX truck.
Thanks for the quick reply!
Matt M.
