1 members (jmoore),
124
Mod | | | Forums66 Topics128,093 Posts1,056,478 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2002 Posts: 23 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 23 | I'm trying to get my cab ready to go out for paint and a last minute check of things has revealed the wood brace under the floor/door sill is rotted on my truck. I have managed to remove all the bolts and but will have to break/cut some small welds to get the rest of the wood peice out. At first I thought the wood was approx. 14" x 2.34/4" x 1" thick but now it seems longer ( 18-20") and has a step in it. Does anyone have a pattern for this or any info. I know it is late but the truck is going out this weekend and I could make new peices and get them out after, but my wood is so bad, its not really going to be good for a pattern . 1940 Chev 1/2 ton Canadian truck | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | ?? My 40 has no wood around / under the sill area. Cab sits on wood blocks alone. Is it possible someone added this later ? My truck was US built if that makes a difference | | | | | Joined: May 2007 Posts: 39 New Guy | | New Guy Joined: May 2007 Posts: 39 | axle 50,
jim carter trucks sells the pieces you are looking for, on page 17 of there early truck catalog. give them a call they might give you the dimensions you need. good luck
thirtyniner
39 chevy 1/2 ton 48 chevy fleetline aerosedan
| | | | | Joined: Jan 2007 Posts: 20 New Guy | | New Guy Joined: Jan 2007 Posts: 20 | axle50, I know the wood pieces that you are talking about, but have no idea where you can get replacements. I have a Canadian 40 Chev as well. I haven't seen the bottom of a cab on a US 40 so can't tell you if they are only on Canadian trucks. Here are a couple of pictures of the wood blocks that are still installed on my truck. Pics of wood blocks behind rockers They are rotted as well, so if you find a source, I would be interested in hearing about it as well.
1940 Chev pickup
“Make the world a better place, save a rusty truck.”
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Interesting. The US models have a small wood block approximately 4" X 3" at the overlap of the metal floor and the cowl with three bolts through it. I had no idea the Canadian models were different. Looks like you got your work cut out for you 4tChev. | | | | | Joined: Oct 2002 Posts: 23 'Bolter | | 'Bolter Joined: Oct 2002 Posts: 23 | I think the wood pieces are specific to Canadian trucks, (heavy bracing for all those cold Sask. farmers and all there pairs of long johns in the winter) I might have another truck to try and get the wood out from so I will keep you all posted (thought about industrial plastic as well as the oak,'cause it won't ever rot! | | |
