Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (3B, 1955 1 Series), 36 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#1270361 06/26/2018 8:48 PM
I have a 49-3100 235 with a corvette exhaust manifold dual exhaust. I have Porter mufflers located just before the rear axle. The sound is good but very mellow. I would like something a little louder but still mellow. Anyone suggest different mufflers?
dougs #1270367 06/26/2018 9:45 PM
Patrick's sells an expensive, but very nicely made stainless-steel dual-exhaust/muffler kit for Fenton dual-exhaust headers.
The sound is distinctively "throaty" (on the 1960 261 in my 1954 Suburban).
Too loud for me.
My guess is the cab noise would be more civilized with a pickup cab.
Picture is attached below.
Here is Patrick's catalog. Scroll way down to CHEVY DRESS UP PARTS.
"1947-1955 1 SERIES 1/2 TON CHEVY OR GMC PICK-UPS
Stainless Steel Exhaust System, complete for use with Fenton Headers………………………………………$675.00 Includes head pipes, muffler, tail pipes, clamps and hangers, complete. Exclusive side-by-side, "shotgun" tail pipes. Fabulous sound, awesome appearance. (long-bed GMC 1/2 tons require extensions. Optional $59.95 w/clamps)"
If your header "dumps/drops-down" like the Fenton header, that set will work.
(forward exhaust-pipe angle drops about straight down, and the rearward exhaust-pipe angle slants to the rear)
If you only want the muffler, send me a Private Message - I will measure the diameters of the pipe fittings. I think they are probably 1.5" diameter.
That two-in/two-out muffler is loud/throaty. The pipes exit behind the driver's side rear wheel.
Be fore-warned about buying directly from Patrick's. It seems that he has become quite unreliable.
dougs #1270370 06/26/2018 10:02 PM
Thank you for your response. I have the entire exhaust installed, so I'm just looking for a little louder mufflers.
dougs #1270390 06/27/2018 12:43 AM
V
V Offline
I'm running a Flowmaster 40 Delta flow on a non-GM V8 and it's pretty mellow at idle and low speed but wakes up when I want it to.
I'm also running dual Glasspacks on a SBC and they are way too loud.
Select the right muffler
