| | | Forums66 Topics128,078 Posts1,056,039 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2017 Posts: 83 Vintage Truck & Tractor | | Vintage Truck & Tractor Joined: Feb 2017 Posts: 83 | The question is , I have the heater hose routing as normal. But I also have a heater hose coming from the lower left side of block. There is a pipe nipple coming out of left lower block and then an elbow with a valve. This transitions to a heater hose that loops over top of engine to a Y splice on heater hose. It was / is for an electric heat pump, for winter.. Can I just eliminate the pipe nipple, plug it off and remove.the heat pump and Y. ? OH Yeah, this is on a 51 3800 with a 216 engine . Thanks guys.
Current project; 1961 C20, 235 I6
| | | | | Joined: Feb 2017 Posts: 83 Vintage Truck & Tractor | | Vintage Truck & Tractor Joined: Feb 2017 Posts: 83 | I figured it out. The place on the left side is the block drain they were using for a source of coolant for the heat pump.
| | | | | Joined: Dec 2014 Posts: 678 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 678 |
1951 Chevy Panel Truck
