1 members (classicchevs), 101 guests, and 2 robots.
Topics128,093
Posts1,056,474
Members48,444
#127032 06/29/2007 3:35 PM
I'm trying to get my cab ready to go out for paint and a last minute check of things has revealed the wood brace under the floor/door sill is rotted on my truck. I have managed to remove all the bolts and but will have to break/cut some small welds to get the rest of the wood peice out. At first I thought the wood was approx. 14" x 2.34/4" x 1" thick but now it seems longer ( 18-20") and has a step in it. Does anyone have a pattern for this or any info. I know it is late but the truck is going out this weekend and I could make new peices and get them out after, but my wood is so bad, its not really going to be good for a pattern . 1940 Chev 1/2 ton Canadian truck
#127033 06/29/2007 9:12 PM
?? My 40 has no wood around / under the sill area. Cab sits on wood blocks alone. Is it possible someone added this later ? My truck was US built if that makes a difference
1940 Chevy KC 1/2-Ton
#127034 06/29/2007 9:43 PM
axle 50,
jim carter trucks sells the pieces you are looking for, on page 17 of there early truck catalog. give them a call they might give you the dimensions you need. good luck
thirtyniner
39 chevy 1/2 ton
48 chevy fleetline aerosedan
#127035 06/30/2007 3:04 PM
axle50,
I know the wood pieces that you are talking about, but have no idea where you can get replacements. I have a Canadian 40 Chev as well. I haven't seen the bottom of a cab on a US 40 so can't tell you if they are only on Canadian trucks.
Here are a couple of pictures of the wood blocks that are still installed on my truck.
Pics of wood blocks behind rockers
They are rotted as well, so if you find a source, I would be interested in hearing about it as well.
1940 Chev pickup
“Make the world a better place, save a rusty truck.”
#127036 07/02/2007 6:59 PM
Interesting. The US models have a small wood block approximately 4" X 3" at the overlap of the metal floor and the cowl with three bolts through it. I had no idea the Canadian models were different.
Looks like you got your work cut out for you 4tChev.
#127037 07/09/2007 5:30 AM
I think the wood pieces are specific to Canadian trucks, (heavy bracing for all those cold Sask. farmers and all there pairs of long johns in the winter) I might have another truck to try and get the wood out from so I will keep you all posted (thought about industrial plastic as well as the oak,'cause it won't ever rot!
