6 members (Jon G, 55shaker, Hanks custodian, latroca52, rfs56trk, BC59), 67 guests, and 5 robots.
Topics128,185
Posts1,057,284
Members48,467
I'm looking to make the '46 more freeway friendly and change out the rear end. I've located a 14 bolt, 8 lug, full floating rear with a 3.73 ratio. From what I'm reading it isn't that big a deal to swap them out, moving the spring mounts seems like the biggest issue. I was wondering if there is someone out there who sells replacement ring and pinion gears for the original rear end so I could just replace those. Chevys of the 40s has a ring and pinion set but it's only for 1/2 ton trucks.
Joe
1946 Chevy 3/4 Ton Flatbed
Tearing her down
Story in the DITY Gallery
More images
Crusing in the Passing Lane
Check your Wheel Mounting Surface (WMS) to get the correct width. Might have to change spring perches(easy).
Ed
Hi Ed,
I've got a buddy who is a welder. He seems to think it's an easy job tool I guess I'll pick up this 14 bolt unit with the 3.73 gear set and go with that.
Joe
Tearing her down
More images
Make sure the rear axle you found is a useful width for you before buying it. Not all 14 bolts are alike.
Lots of info and measurements here on the 14 bolt as adapted to our old trucks.
https://www.stovebolt.com/ubbthread.../14-bolt-axle-swap-info.html#Post1249600
•1952 Chevrolet 3800 pickup
---All pictures---
Hi Grigg,
Thank you, that's exactly what I was looking for. I've got a stakebed truck so there are no fenders to deal with but still want to make sure I'm going to have the right geometry. I've got to measure the WMS distance before I go take a look at this rear. That thread deals with AD trucks, would the same info hold true for my '46 3/4 ton?
Joe
Tearing her down
More images
Yes, generally the same info is good for the 3/4 ton and the older (and newer) trucks.
To be sure the swap is right for your situation measure the important stuff, like width from center of each spring, and wheel mounting surface to WMS.
---All pictures---
Well I've located a T5 from a Sonoma and a '54 235 so all 3 pieces should make for a better driveline. Can't wait to get started. I'll try and take lots of pictures.
Thanks again for all the great info.
Joe
P.S. I also located a heater/defroster for those cold winter days out here in So Cal :-)
Tearing her down
More images
