7 members (tclederman, Gdads51, 1955 1 Series, moparguy, Gray_Ghost, Otto Skorzeny, 1 invisible), 75 guests, and 10 robots.
Topics128,078
Posts1,056,027
Members48,433
** Anyone know what the torque value for the body mount bolts on a 53 Suburban should be?? ** 2 half inch bolts up front with the remainder being 3/8 inch bolts. Thanks
Sir Searchalot
Sir Searchalot
Due to the need to obtain proper/limited compression of rubber parts, it is done by measurement, not torque. Except in cases where there is a metal sleeve to control the crush/compression.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0102.htm
For normal grade 5 fastening: 3/8 course torque is about 30 Ft Lbs and 1/2 course is about 75 Ft Lbs. This is a general torque with no rubber involved. Torque charts differ due to plating, grade, dry or lubricated.
The answer is: tight, but not too tight. smile If there are split lock washers, they need to be squeezed flat.
