1 members (1 invisible), 65 guests, and 0 robots.
Topics128,049
Posts1,055,740
Recently changed the fuel sender on my 56 pickup.The truck started and ran ok before I changed the sender(all be it 2 weeks ago when it ran last).Now it won't start.Had a look at the spark plugs and they were dry.I took the fuel line off where it enters the carb(2 jet Rochester)and fuel spat out with some air bubbles and seemed to be under pressure.What can I check next.Could the fuel line be air locked and how do I clear it.Anything else I can check.Thanks in advance.
Crusing in the Passing Lane
Float stuck? Pour some fuel down carb., does it fire? Built in filter in carb., is it clear?
Ed
If you have a behind-the-seat tank, you have the pipe coming out of the top of the tank at the sending unit. Your fuel pump therefor needs to pull fuel up hill to get fuel out of the tank. I small leak in the fuel line between the fuel tank and the fuel pump will suck air, thus preventing the fuel pump from pulling fuel.
Check all fittings for tightness between the top of the tank and the fuel pump.
An empty fuel tank will cause your symptom as well. smile
