2 members (cmayna, Gray_Ghost), 168 guests, and 0 robots.
Topics128,114
Posts1,056,613
Members48,450
Hi all, I’ve recenty acquired a 1948 GMC 300 and it has two factory e brake handles side by side. Any ideas as to why there might be two? It is an old Gin Pole lift truck with a pto driven winch.
Thanks in advance!
Logan
2010 Silverado 2500HD
1947 GMC 300
Big Bolt Forum Moderator
Hi Logan, welcome to the site. I can't answer your question but I'm sure someone more familiar with that era of trucks will chime in shortly!
Mike
Crusing in the Passing Lane
It sounds like the handles might be for PTO engage and brake. Have you tried to follow the linkeage?
Ed
DP Offline
I agree with Ed. On my 1948 GMC 1.5 ton, there is one lever just to the right of the shift lever, it is the e/parking brake lever, it has a release handle. To the left of the shift lever, and further back toward the seat, there are 2 levers on one pivot, one engages the PTO, the other engages the dump. Yours may have one lever on that pivot to engage the PTO. As suggested above, follow the linkages and let us know what you find!
1948 GMC 1.5 ton Dump Truck
thanks guys i will keep you posted!
Logan
1947 GMC 300
