5 members (Hotrod Lincoln, fonz8261, baldeagle, walter74, 1 invisible), 97 guests, and 2 robots.
Topics128,134
Posts1,056,416
Members48,441
#1269692 06/20/2018 8:08 PM
Need a few lug studs for 57 4400 frt wheels. 10 lug maybe part number of replacements.
1959 Chevy Viking 60 & Wrecker
See I told you it would work. That Beaver Cleaver will do anything.....
3B Offline
Hy cdandelivery, the o.e.m. p/n appears to be 5845873, hope that helps.
If you can get one out take it to your local NAPA and see if they can match it. You might be surprised.🛠
Big Bolt Forum Moderator
are the ones on the left side LH threads like they are on the 6400 6 lug stud centered wheels?
Mike
The Chevy 1-1/2 ton should have hub centered wheels, and therefore all right handed studs.
By 57 I believe the Chevy 2 Tons were stud centered Budd wheels, and so were GMC 1-1/2 and 2 ton. Left hand studs on left side of truck.
•1952 Chevrolet 3800 pickup
---All pictures---
Thanks, Grigg, I was not sure if the hub centered wheels used LH threads on the left side or not, now I know!
Mike
