2 members (Gdads51, Guitplayer), 76 guests, and 3 robots.
Topics128,162
Posts1,056,950
Members48,458
Offline
The 4 speed transmission shift arm is sloppy on my 1955 Chevrolet first series 3100 pickup. This has caused me to grind the gears from third to fourth. I have a spare transmission that seems to be tighter. There are eight bolts holding the cover on. Can I just switch the arms and top plate without it turning into a major project. If I remove the pin that looks as though it is holding the arm, will the arm come out? Will that make it easier? The shop manual says be careful of springs,pins, levers, etc. On a previous thread someone made it sound fairly simple. I am a backyard putz. Am I missing something, or can someone give me some advice, or should I find a professional, which might be like finding a needle in a haystack!! Thank you.
Assuming you have the sm420 with granny low transmission. Two things could be the culprit. First the end of the shift arm could be worn and second, the three-four shifter yoke could be worn too.
You can remove the top of the spare trans by removing the 8 bolts, make sure both transmissions are in neutral. then replace the entire assembly to the transmission you are using. Just align the sliders on the main shaft with the yokes of the top loader and it will slip right in.You possibly might need to slide the reverse/first gear a bit forward or backward to fit it all in nicely. Easy/peasy
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
I had a the same problem -sloppy shifter - with my 49-3100 with a 4 speed SM420. I put a new shifter, spring and fulcrom pins and there is no more sloppy shifting. Got all parts from Novak Transmission.
Offline
Thanks for the information. I always have the fear of messing things up! Is Novak Transmission in your area, or can you tell me how to get in touch with them? Thank you.
Offline
Thank you for your reply. How can I tell if I have the SM420 transmission? I do have the granny gear.
Google sm420 and look at the pictures. Keep in mind depending on the year of the truck the rear bearing and yoke will be different for the torque tube type driveshaft then say an open drive line. Some heavy trucks might have a ebrake assembly off the rear yoke as well.
You can always post a picture of your top cover too.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Crusing in the Passing Lane
Novak is in Salt Lake City, or suburbs.
Ed
Riding in the Passing Lane
You do not have to remove the pins to remove the shifter lever. . Take a pair of vise grip pliers. Press down on the coller on top of the trans. & turn it about 25 degrees CCW. The lever should lift
out.
1972 Chevy c10 Cheyenne Super
