Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Hotrod Lincoln), 136 guests, and 3 robots.
Topics128,281
Posts1,058,465
Members48,490
#126960 06/26/2007 10:06 PM
Put the hood back on our 53 yesterday. After reading all the previous posts about troubles encountered with this, I wasn't looking forward to it. But we got a brake, took only 2 hours and I like the fit. I followed the directions found in previous posts, somewhat. We measured the brace rods in the engine compartment and only had to adjust a quarter inch or so. I used a level on the fenders and radiator support to make sure they were level. We started by putting in the shoulder hex bolts loosely. We then put the spring bolt on. We adjusted the plate from inside the cab. We slowly brought it into alignment. We finally adjusted the hood latch for a real good fit. Maybe it was beginners luck, but I sure was thankful that it turned out to be so easy. Frank
#126961 06/27/2007 3:25 AM
Glad it worked out for you. The hood can be a real bugger to get fitted up.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
