6 members (Nick in Manitou, Wayne67vert, 1955 1 Series, Oswald, Woodcmiami, MRMEROTH11), 147 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
I have my truck down to just the frame and I am planning to sandblast soon, I am also planning on overhauling/rebuilding the front end suspension. I am wondering if I should dissemble the suspension system before sandblasting so I can more thoroughly remove rust and debris from the individual parts, or if I should leave it all intact.
The front end is sagging some, and I assume this is due to fatigue on the torsion bars, so where would I get replacements? Also is there any site that sells thorough rebuild kits for the front suspension? I know that Ecklers has some steering kits and suspension parts, however I'm hesitant to buy from them since in the past they have marketed an item as fitting a '62 C10, but it was totally wrong.
Any help appreciated!
College student trying to restore grandad's 62 C10
If I was going as far as you already have gone I would certainly take the time to go all the way. You’ll be happy you did.🛠
Sir Searchalot
Sir Searchalot
Any sagging will not be fatigued torsion bars. Could be upper and lower control arm joints/ball joints, control arm shaft and bushings or just torsion bars need adjustment. It all depends on what you mean by sagging and if it is really "sagging". Full inspection, with wheels off the ground, is necessary to discover loose/worn components. As far as disassembly of suspension, I would say no. If you are going to replace parts, they will be new. If there are areas that are missed by blasting, just wire wheel in that area. Also logistics need to be considered. If you need to move chassis around on it's wheels, then you can't take it apart. Also, do not take anything apart before you have the new part. So as to be sure you can get the part and to see how it goes back together as you do one side at a time.
Many front end parts available at Classic Parts of America. see 60-66/chassis and steering/chassis. Forget Ecklers, your truck is too new. Front end parts are available at Classic and FLAPS. You are in for some really, really expensive parts, so be sure you need them.
Be careful what and where you sandblast. If you are really using sand you can damage bearings and other moving parts. Sand will get into real tight places. Wheel bearings, differential bearings, bushings, ujoints, ball joints.........you are forcing high pressured sand into small cracks.
