1 members (homer52),
118
Mod | | | Forums66 Topics128,281 Posts1,058,469 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | So, Florida DMV is giving me a hassle with registering my 3100. Going on 2.5 years. My vin plate somewhere over the years got pinched, and the bottom corner is missing, which cuts most of the last number off of the plate. I contact the Missouri DMV, where it was last registered, and the VIN they have on record doesn't include the last number at all! So, I'm thinking that if I can find out how many 3100s were built in 1953, I might be able to use the process of elimination to determine the last number. The number I have is: H53S01703___. Number has a rounded top, looks like a 2 to me, but could perhaps be the top of a zero, two, eight, or nine.
Thanks for any help or suggestions, as the DMV is nonresponsive.
1953 3100
Melbourne, FL Veteran
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Don’t you have the title with the number?
| | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | I do not. The truck was bought by a German exchange soldier while stationed at Ft. Leonardwood, MO. I bought it from him while in Europe. He had import paperwork. I did get the MO DMV to look up the last registration, which was in 2000, as I do have photos of the truck with the license plate. Missouri is good with it.
1953 3100
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | So the Vin number Missouri used was H53S01703?
and Florida wont accept that?
Florida want you to stamp and new number on the door post? Then get it verified
Do you like washing fire trucks on the weekend?
You might need help from someone who specilizes in these matters Try a diffrent DMV office
If I find the thread with a similar porblem Ill link it
Hang tight
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Gentlemen, be very careful here. The discussion of altering VIN plates or VIN is not approved by Stovebolt.com. If you will answer the OP’s question as posted I will leave the thread up. Should you choose to ignore the rules I will take it down.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Good info Tim  These things can be a bear to title even with the correct paper work I had title, regestration all with the number on my data plate and the dmv guy still gave me a hard time “That can be changed” Had to call a supervisor out , almost a bad day Shaanix Hopefully some one from your area will chime in with florida info | | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | Seems the FL DMV just wants to ensure that it isn't stolen somehow, and figure out what that last digit is. They are pond water slow, and I'm just trying to figure out how to 'help them'.
1953 3100
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Yeah, your in a pickel Even if you determine the number or find in on the import papers ,then what?
Florida must have a process for this Some states will assign a vin and place it on the vehicle.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yeah, your in a pickel Even if you determine the number or find in on the import papers ,then what?
Florida must have a process for this Some states will assign a vin and place it on the vehicle. Exactly I had excellent documentation on my trucks, but I had removed the body Suburban's ID plate and used new rivets for attachment of a reproduction plate (carrying the original plate in the glove box). That was OK in New York, but it is a "no no" in NC. Reason: how do they know that my nice new ID plate is original-code for my body/truck? I had to get a bonded title (but, they have totally denied me any options, if I had not had my documentation). They bonded the title based on depreciated original cost of the truck (they could have required a bond on the present appraised value of the truck). They placed a new VIN tag on my door frame. | | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | Here's your serial number break down, which you probably already know... H53S01703 H = 3100 53 = year S = St Louis 01703_ = unit number The unit numbers started at 001001, so you are defiantly missing a number. If the DMV looked up each of the 10 possible ending numbers they could see if the other 9 were still in use and rule them out... Without doing that there's no way to ever really know what the missing number is/was. Maybe Missouri would tell you who had the truck before their last known guy so you could work backwards in hopes of finding the whole number from a past owner? Grabbing straws here...good luck! Mike B  | | | | | Joined: Nov 2017 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2017 Posts: 28 | I'm a newb here but I thought I saw a post somewhere that someone said the VIN was stamped into the frame somewhere? Maybe that post related to a different model than u have but I wanted to throw that idea out there. | | | | | Joined: Nov 2000 Posts: 1,975 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,975 | No frame stamped numbers on A-D trucks. Sorry.
Professional Novice
| | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | Wow. Horror stories. Well, it took 8 months and 3000 Euro in Italy......hard to believe that it's worse here in the good ol' US of A. Disgusting.
1953 3100
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Tell that to the NC DMV. Their information is that there was a secret frame ID code.
I showed them a bare frame. | | | | | Joined: Mar 2004 Posts: 6,242 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,242 | The "secret frame number" started with the normal frame number that everyone knows about in 1955...the frame was double stamped with the second serial number 3' behind the first number putting it under the cab. Note, the frame number does not include the "series" type...it just has the year, plant and unit number. Mike B  | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | That's the one. Mike
Not to be found on my 1954 trucks. | | |
