1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#126928 06/24/2007 3:54 PM
I am getting ready to do some welding...what is the thickness of the steel on my 55?
HURRY UP AND WAIT 55 235 3/4
#126929 06/24/2007 5:44 PM
It's roughly 18 guage.
Bill Burmeister
#126930 06/24/2007 7:12 PM
18 ga = .0478
19 ga = .0418
20 ga = .0359
Measure a piece w/o the paint on it and you'll see what you have. Various gauges were used on different parts of the cab/body. Hope this is of some value to you.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#126931 06/25/2007 3:20 AM
The stock thickness is 19 ga on exterior panels. But since 19ga is hard to find I would go with 18ga crs. CRS is cold rolled steel.
Currently working on custom metal and How to videos.
1949 and 1972 chevy trucks
70 chevelle SS455
Pictures of my work and projects
http://community.webshots.com/user/sevt_chevelle
#126932 06/25/2007 12:12 PM
Thanks Guys..wish me luck with the heat...its been a long time..I better practice a bit.
#126933 06/26/2007 5:16 AM
Dave..Just saw the step by step work you did on your 5 window..That looks great. I will be using the same color Juniper..some day that is..
#126934 06/26/2007 2:19 PM
Eric, where you guys buying your crs sheet from??
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#126935 06/28/2007 2:12 AM
Any metal supply store will have crs.
Just look in the yellow pages for metal supply or metal fab.
Just make sure you dont get hot rolled steel as it has a scale on it that NEEDS to be removed before you do anything with it. Cold rolled closely matches the draw quality steel that the OEMs use.
A big supply place in chicago is Ryerson steel, they might even have 19ga, key word might...Eric
PS I just bought a 4x10 sheet of 18ga in KC it was 80 bucks and some change.
70 chevelle SS455
#126936 06/28/2007 3:23 AM
Thanks Eric, I’m familiar with the different grades of sheet and the alloys. I was part owner and shop Forman in a welding fabrication/machine shop for many years and we dealt with Ryerson, Central and a bunch of the smaller steel suppliers in the area. Now that I have been out of the loop for a decade or so all of the sales reps have retired or moved on and I don't have any contacts. Most have a minimum charge and most won't deal with the public. Just thought you guys might have a retail source that you used for small quantities. I see there are a lot of suppliers that are going online now days.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
#126937 07/15/2007 11:46 AM
there's always metalsdepot.com - small batches, quick/REASONABLE shipping.
[b]1957 Chevy Big Window 3100[.b]
More pix in Picasa
It ain't broke 'til you can't fix it any more.
#126938 07/23/2007 7:12 PM
FYI
I've bought square tubing here for re-inforcing the floor..I noticed they do carry 19 GA..Ordered online and was on my porch the next day.
http://www.metalsupermarkets.com/MSC-MetalGuide.aspx
Keith
