| | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | Have a bit of an issue with my brake lights. This switch has been working properly for more than a year. Now the brake lights do not come on unless one of the turn signals is active. Turn right and left brake light is on, turn left and right brake light is on. Not turning then there are no brake lights at all. I have power at the rake light switch and power to the red wire when the brakes are applied. I have a new switch on the way but would like to get to the bottom of this.
Jackie | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Try checking the stop switch on the firewall
See if the arm is broken
Have someone look at lights while you remove and touch the two wires together | | | | | Joined: Jan 2017 Posts: 120 Retired Construction Worker | | Retired Construction Worker Joined: Jan 2017 Posts: 120 | Jackie ..in my reading up on turn signals lately,, I find that a bad flasher can cause some different malfucntions . It would be interesting to find out ,,that is ,,if you got another flasher for a backup and plug it in and see if that fixes your problem..if you have not already tried this that is .
Directions are just another man's Opinion
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Good advice, DADS50
I had an old switch that worked intermittently.
If you have to buy one, check Rockauto.com ($14 delivered) agains other vendors. | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | Ok I removed the wires from the brake light switch and jumped them and no brake lights. I have 6.5 volts at the red wire going into the turn signal switch with the brake applied.
Jackie
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Did you have voltage at one of the wires on the stop switch?
Did you check the fuse on the firewall(if your using it)
Touching the wires should of made the stops light up
| | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | DADS50, Yes I have voltage at one terminal of the brake light switch when pedal is not pressed, and voltage at the other terminal when it is pressed. I'm thinking I have a broken contact inside my signal switch? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Strange they didn’t light up when you touched them together
Try a new flasher like suggested above
But your initial description sounded like a stop switch
Did you try the emergency flasher?
Do the brighter tails come on when you engage them? | | | | | Joined: Jul 2015 Posts: 135 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 135 | I disassembled the turn signal switch and found that the screw that holds the rotating contacts together was loose. The turn signal lever is keyed to a post that rotates the contacts. Since this screw was loose it caused the key to wear down and the contacts to move willy nilly. I honesty don't know how anything was working. Fortunately I did have an old switch exactly like this one that failed in a different fashion that I robbed parts from. Brake lights are back in business....I'll put the new switch somewhere safe for future use!
Thanks for the help
Jackie
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | |
