Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (C10 - C90 Bill, cmayna, Otto Skorzeny), 104 guests, and 4 robots.
Topics128,290
Posts1,058,557
Members48,491
V
V Offline
Are the fenders and doors and hood the same on a 50 1/2 ton and a 54 3/4 ton? I would like to put the 54 stuff on my 50 and still use the 50 grill. Thanks Virg :confused:
No, they do not match.
Paint & Body Shop moderator
Anonymous
Unregistered
Anonymous
Unregistered
The only problem you will have is trying to use the 50 grill on the 54 fenders. They will not work. I would suggest selling the 54 fenders and buying the 48-53 fenders. The 54 are rarer and it is a semi-mortal sin to cut them up. There in Kansas there should be old AD series chevy trucks on every corner. Start calling around and you should be able to find some.
Question - Will the AD fenders from a 1/2 or full ton fit on a 3/4 ton truck or are the specks different?
Still At It
48 Thriftmaster
64 Impala
62 Impala
Half the fun is making the mess!!!!!The other half is figuring out now what do I do?????
I realized they use the same sheet metal but aren't some longer or shorter? I thought the opening on the ton fenders were bigger. Maybe its because the ones I found in great shape were off a ton school bus.
Still At It
48 Thriftmaster
64 Impala
62 Impala
