1 members (Peggy M), 95 guests, and 1 robot.
Topics128,101
Posts1,056,182
Members48,436
#1267907 06/02/2018 7:28 PM
Don't really know where to post this. I recently ordered a radiator surge tank from the Filling Station. It came with 2 different ID labels to put on the side. One is vinyl self adhesive, single color. The other is a multi-color copy of the original classic label but is a water base decal. Needless to say, I would like to use the decal, but I am concerned about applying it to something mounted in the engine compartment. Is there something that I can coat it with that will water proof but wont cause it to wrinkle and blister? And no, the Filling Station did not have an answer - they only sell it.
Bob
BobS46
I got a decal and they said to shellac it after it dries.
Don
Can’t begin to tell you how much I hate the name Stovebolt.
Don
Can you explain please. Sorry for my ignorance.
J. F.
Shellac is a clear paint product similar to varnish. From Wikipedia -- Shellac is a resin secreted by the female lac bug, on trees in the forests of India and Thailand. It is processed and sold as dry flakes and dissolved in ethanol to make liquid shellac, which is used as a brush-on colorant, food glaze and wood finish.
Also from Wikipedia -- Varnish is a transparent, hard, protective finish or film that is primarily used in wood finishing but also for other materials. Varnish is traditionally a combination of a drying oil, a resin, and a thinner or solvent.
I use Rustoleum clear enamel on decals for my truck and RC airplanes. The trick is to spray a light mist coat and let dry. Then add light coats, letting dry between. If you try to get the clear on too thick, the chemicals in the paint and or the propellant will affect the decal. Good luck!
I decided not to shellac because it would shine the dull black finish I want on my air cleaner. Decals are cheap.
Don
There are other satin finish clear products you could try (assuming they don't wrinkle the decal when applied). A Varathane product comes to mind. I think I have a rattle can of satin finish.
Used Testors clear lacquer, masked the area down close to the decal, sprayed several light coats. Works fine.
BobS46
