10 members (MickeyP, MRMEROTH11, Gdads51, TexasJim50, 2-Ton, Southerntruck, Ponchogl, JW51, Shaffer's1950, 1 invisible),
133
Mod | | | Forums66 Topics128,132 Posts1,056,378 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Don't really know where to post this. I recently ordered a radiator surge tank from the Filling Station. It came with 2 different ID labels to put on the side. One is vinyl self adhesive, single color. The other is a multi-color copy of the original classic label but is a water base decal. Needless to say, I would like to use the decal, but I am concerned about applying it to something mounted in the engine compartment. Is there something that I can coat it with that will water proof but wont cause it to wrinkle and blister? And no, the Filling Station did not have an answer - they only sell it. Bob
BobS46
| | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | I got a decal and they said to shellac it after it dries.
Don
Can’t begin to tell you how much I hate the name Stovebolt.
| | | | | Joined: May 2018 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2018 Posts: 51 | I got a decal and they said to shellac it after it dries.
Don Can you explain please. Sorry for my ignorance.
J. F.
| | | | | Joined: May 2015 Posts: 11,074 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,074 | Shellac is a clear paint product similar to varnish. From Wikipedia -- Shellac is a resin secreted by the female lac bug, on trees in the forests of India and Thailand. It is processed and sold as dry flakes and dissolved in ethanol to make liquid shellac, which is used as a brush-on colorant, food glaze and wood finish. Also from Wikipedia -- Varnish is a transparent, hard, protective finish or film that is primarily used in wood finishing but also for other materials. Varnish is traditionally a combination of a drying oil, a resin, and a thinner or solvent.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | I use Rustoleum clear enamel on decals for my truck and RC airplanes. The trick is to spray a light mist coat and let dry. Then add light coats, letting dry between. If you try to get the clear on too thick, the chemicals in the paint and or the propellant will affect the decal. Good luck! | | | | | Joined: Jun 2017 Posts: 370 Shop Shark | | Shop Shark Joined: Jun 2017 Posts: 370 | I decided not to shellac because it would shine the dull black finish I want on my air cleaner. Decals are cheap.
Don
| | | | | Joined: May 2015 Posts: 11,074 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,074 | There are other satin finish clear products you could try (assuming they don't wrinkle the decal when applied). A Varathane product comes to mind. I think I have a rattle can of satin finish.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Used Testors clear lacquer, masked the area down close to the decal, sprayed several light coats. Works fine.
BobS46
