3 members (TUTS 59, Rusted Nut, fonz8261), 141 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
#1268707 06/11/2018 2:27 AM
I have a 1955 235 engine in my truck. It has a Rochester B series carb, auto choke. The choke is presumably close to correct setting. The sheet metal over the engine is not yet in place so I keep a PVC pipe cap over the carb throat, leaving about 0.1" clearance between the carb throat OD and the pipe cap ID. In order to get the engine to start and run well, cold or warm, I need to leave the pipe cap ON THE CARB. If I remove it, the engine slows and dies. I have tried playing with the mixture adjustment - all the way in (lean?) has no effect, all the way out has little effect. Note - the air cleaner is not on the carb for any of this.
Bob
BobS46
Insomniac
Insomniac
Sounds like you need a carb rebuild kit.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I would never assume that.
Correct always begins with the choke blade completely closed with the engine cold (off at least 4 hours), and with this carburetor open 9/64" (.141") measured from the edge of the choke to the throat ID when the engine starts. If it doesn't close all the way, or opens to more than .141" it will be too lean.
Carburetion specialist
If this carburetor has an automatic choke, would suggest at least checking the adjustment:
http://www.thecarburetorshop.com/Automaticchokes.htm
A choke out of adjustment would cause your symptoms.
Jon.
The Carburetor Shop
From Panic:
Not sure that I understand this. Let me rephrase and correct me if I am wrong. Engine off, cold, choke should be closed, presumably with the choke spring under just enough to cause this. When the engine is started, the intake vacuum, operating against the choke spring force, will cause the choke to open to less than .141"
Bob
BobS46
