1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1268588 06/10/2018 12:50 AM
Is there any reason to "seal" the bolts screwed into something like a differential. Or do we rely on the bolt stretching and sealing the threads.
I'm wanting to use a little pipe sealer in my threads.
Sorry to ask Stupid questions. I've been a Electrician for too long.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
SavannahDog #1268589 06/10/2018 12:56 AM
Normally no sealant is required. Most bolt holes do not go through into the liquid storage area. In other words they are a blind hole. Those that do go all the way through are sealed when torqued to specs.🛠
SavannahDog #1268689 06/11/2018 12:37 AM
On my two differentials the bolt holes that hold the differential to the housing and the rear cover extend into the inside environment. It is common to see lock washers on these bolts and they do not seal. However the hypoid fluid is pretty thick.
1951 1 Ton Completed
SavannahDog #1268691 06/11/2018 12:41 AM
Crusing in the Passing Lane
RTV silicone is good for these situations.
Ed
SavannahDog #1268694 06/11/2018 12:52 AM
Some people use copper crush washers, I have read.
Professional Novice
