0 members (),
196
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | Looking to get replacement engine mounts for a '65 C60. Are these still available? Local parts store did not have a listing for medium duty trucks this old. Any help appreciated. | | | | | Joined: Jul 2008 Posts: 326 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 326 | A picture would sure help. GM may have used the same mounts across vehicle platforms and production years.
SimS | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I bet they are available. Show a picture and I’ll dig up NAPA part numbers for what I suspect you have. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy red450IH and guys, does the truck you're inquiring about have a V8 engine or an inline six? | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy guys, I found GM p/n 3827521 which crosses to Napa p/n BK6021090, also Anchor p/n 2309, appears to be the same part number V8 or 6 cylinder, hope that helps. | | | | | Joined: Feb 2001 Posts: 95 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 95 | I looked up the part numbers 3B posted, that is exactly what mine are! Thank you 3B! I had searched a long time to no avail. From looking up the numbers it seems these were also used in the GMC light duty trucks (one ton & smaller) with the V6 305 / 351. | | |
