0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2017 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 23 | Searched the forum and discussions are typically about the leaf spring shackles. I am talking about the rear cab mounting shackles (item 9.009 Chevy Master Parts Catalog). The shackle assy. has two pins with 7/16-20 threads, 2-7/8" long pressed fit (serrated at head). These pins can be easily tapped out. The bushings are included in any vendors cab mounting kit but I need to replace one of the pins as it is corroded and don't want to buy a complete shackle assembly. Has anyone ever replaced this pin and where can you find them. Last resort, guess a carriage bolt would work? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Year and size of your pickup truck? | | | | | Joined: Feb 2017 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 23 | I have a 52 chevy 3600. Per the Parts catalog, looks like same shackle for 49 thru 54. | | | | | Joined: Jul 2000 Posts: 2,192 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,192 | You missed this recent thread when you searched the forum? Shackles
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Feb 2017 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2017 Posts: 23 | Yes I did! Thanks. The pressed pins will probably be hard to find if at all. The link provided a McMaster number. Thank you for providing that link. | | | | | Joined: Mar 2018 Posts: 111 'Bolter | | 'Bolter Joined: Mar 2018 Posts: 111 | Fancyt, the shackles are working just fine as per my other thread.
The press fit bolts might be available somewhere but for me 100% originality was not the end goal. The eyes would be harder to replicate so I simply made up the end plates which is easy enough.
Best of luck, | | | | | Joined: Jun 2018 Posts: 93 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 93 | Where do you get replacement cab mount shackle bushings?
Jason Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.) 1950 Chevy 3100 | | |
