5 members (55shaker, Rich'sToys, 59 fleet, pdlightning, 1 invisible), 140 guests, and 5 robots.
Topics128,077
Posts1,056,032
Members48,433
#1267922 06/02/2018 10:09 PM
Searched the forum and discussions are typically about the leaf spring shackles. I am talking about the rear cab mounting shackles (item 9.009 Chevy Master Parts Catalog). The shackle assy. has two pins with 7/16-20 threads, 2-7/8" long pressed fit (serrated at head). These pins can be easily tapped out. The bushings are included in any vendors cab mounting kit but I need to replace one of the pins as it is corroded and don't want to buy a complete shackle assembly. Has anyone ever replaced this pin and where can you find them. Last resort, guess a carriage bolt would work?
Year and size of your pickup truck?
I have a 52 chevy 3600. Per the Parts catalog, looks like same shackle for 49 thru 54.
Insomniac
Insomniac
You missed this recent thread when you searched the forum?
Shackles
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Yes I did! Thanks. The pressed pins will probably be hard to find if at all. The link provided a McMaster number. Thank you for providing that link.
Fancyt, the shackles are working just fine as per my other thread.
The press fit bolts might be available somewhere but for me 100% originality was not the end goal. The eyes would be harder to replicate so I simply made up the end plates which is easy enough.
Best of luck,
1951 3100 5-window
with a '55 235/floor mounted 3-speed
Some of the story in ODSS
Most of it in The Shops Area wink
Where do you get replacement cab mount shackle bushings?
Jason
Working on my first restomod on a 1950 3100 Shortbed (235 engine, 3 on the tree, disc brakes, etc.)
1950 Chevy 3100
