3 members (Mike'sPlace, carbking, 1 invisible), 108 guests, and 3 robots.
Topics128,079
Posts1,056,286
Members48,441
#1267117 05/26/2018 9:43 PM
I need to know the inside dimensions of the floor in the cab of a 1966 Chevy C10. Does anyone know?
how precise are you looking for?
~ HB
1962 Chevrolet C10
1962 Suburban
I would like to at least get the cab square the guy before me cut a lot of the floor .
Does any one know the measurements inside floor for 1966 Chevy c10 the person that I got the truck cut the front floor out so I don’t have any points to measure from thanks
FYI, complete replacement floors on evilbay for $169.00.🛠
I will take some measurements tommorrow. Are the doors on? That is the most critcal fitment as far as i am concerned.
~ HB
1962 Chevrolet C10
1962 Suburban
Not really sure what the tolerances might be but here are some numbers off the cab in my garage. Doors are off, but have been fitted.
Also not really sure where to pull good solid measurements from so if these are not what you need let me know I can pull some more.
lf front mounting bolt center to rt front mounting bolt center: 41"
rear mounting bolt center to rear mounting bolt center: 42 1/8"
rt front mounting bolt to rt rear mounting bolt: 41 5/8
lf to rt door channel flange, front (exterior to exterior). Measured close to floor: 67 1/4
lf to rt door channel flange, rear (exterior t exterior). measured close to floor: 67 1/8
rt side front to back of door opening. Measured close to floor above curve of the channel: 35 1/8
~ HB
1962 Chevrolet C10
1962 Suburban
Sir Searchalot
Sir Searchalot
I'm confused as heck. If you have the truck, you just measure that truck you have? You buy a floor and fit it in or cut sheet metal to weld in a new floor. Really not sure what you are doing? Cardboard template is usually the best start. Are you patching. Did the owner cut out the spot welds or hack it all upi?
FYI, to save money, sections are available from $30-$70.
Geezer
Geezer
I don't know if this will help, but here is the Cab Dimensions page from the factory build manual..
Well, I tried to upload, but of course it exceeded the 300mb limit..
Email me, [email protected], and I will send it to you or go to Chevrolet Heritage and download the complete manual for free..
Good luck,
Thirdcoast
1966 C20 LWB, 327 4 Bbl., 4 Speed
Apparently he didn’t get the help he needed or he’s busy working. He hasn’t logged in for a month. 🛠
