Hey, just thought Id share what I found when I pulled the valve cover off my 261. Apparently, Micky had set up shop and was living well on the nuts he filled the cover with. I'm just glad I checked before trying to start this thing. Regards JG
did any of the debris go down the oil return holes?
Tomctom, I used a shop vac to clean out what I could. But I`m sure there are nut fragments and mouse bones all down in there. I still need to pull off the exhaust to check the ports for more free stuff. Wonder whats in there.. Regards JG
My last truck had an oil bath air cleaner on the carb when I got it. I took it off to find a few kernels of corn in the carb. I took the carb off and stuck the hose of my shop vacuum in the manifold... don't know if anymore came out or not.
