| | | Forums66 Topics128,091 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | 1948 Chevrolet Pick-up 1/2 Ton. Need help or any tips on removing the 2 outer door handles (driver & passenger side) I can see there is 1 screw on the outside that is exposed when you turn the handle, is there anything else to get these off ? | | | | | Joined: Mar 2016 Posts: 225 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 225 | Yep, there should be one along the outer edge, underneath the door weather strip. Screws from the inside out, kinda through the outermost edge of the door into the handle. Big flat head slotted screw.
Mike
1951 3100 5 window
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | Bobby--They will stick, I used a plastic putty knife and big screwdriver to loosen the handle, after removing the 2 screws. Then took a wire brush to the round shaft that was rusty/cruddy.... good luck Bill | | | | | Joined: Jun 2016 Posts: 102 Shop Shark | | Shop Shark Joined: Jun 2016 Posts: 102 | Got 'em off!! Thank you all! | | |
