5 members (Bill Hanlon, MRMEROTH11, JW51, Mike Burns, KEVINSKI), 110 guests, and 2 robots.
Topics128,133
Posts1,056,396
Members48,441
#1267689 05/31/2018 5:59 PM
Hey, just thought Id share what I found when I pulled the valve cover off my 261.
Apparently, Micky had set up shop and was living well on the nuts he filled the cover with.
I'm just glad I checked before trying to start this thing.
Regards
JG
did any of the debris go down the oil return holes?
He was having himself a grand old time in a comfy out of the way spot. Sounds like a vacation to me. Glad you spotted it before a start up.
Mike
Well at least now you know what that mysterious squeaking sound was...
Insomniac
Insomniac
I thought a mouse engine was a small block V8. ohwell
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Down here in SoCal its all about the K rats. Its OK to smoke pot but you better not kill a rat! nono
Tomctom,
I used a shop vac to clean out what I could. But I`m sure there are nut fragments and mouse bones all down in there.
I still need to pull off the exhaust to check the ports for more free stuff. Wonder whats in there..
Regards
JG
How did he/they get in there?
My last truck had an oil bath air cleaner on the carb when I got it. I took it off to find a few kernels of corn in the carb. I took the carb off and stuck the hose of my shop vacuum in the manifold... don't know if anymore came out or not.
Professional Novice
