| | | Forums66 Topics128,029 Posts1,055,417 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2017 Posts: 50 On the road again | | On the road again Joined: Apr 2017 Posts: 50 | How do you remove the horn button on my 53? Easy question....... | | | | | Joined: Mar 2001 Posts: 265 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 265 | Jim60,
It is just held on by friction. Just gently pry it out and away from your steering wheel. Use a small flat screwdriver. If you are worried about scratching you steering wheel. Put a rag between the steering wheel and the horn button. It has probably been on there a while. So, it may be a bit stubborn. But, it will pop off with the a little pressure put on it. Hope this helps you out.
Rugo
Steve Rugg 53 3100
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Apr 2017 Posts: 50 On the road again | | On the road again Joined: Apr 2017 Posts: 50 | Thanks, I didn't want to damage it or the steering wheel...... | | |
