0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#1267735 06/01/2018 1:28 AM
On the road again
On the road again
How do you remove the horn button on my 53? Easy question.......
Jim60 #1267744 06/01/2018 2:08 AM
Jim60,
It is just held on by friction. Just gently pry it out and away from your steering wheel. Use a small flat screwdriver. If you are worried about scratching you steering wheel. Put a rag between the steering wheel and the horn button. It has probably been on there a while. So, it may be a bit stubborn. But, it will pop off with the a little pressure put on it. Hope this helps you out.
Rugo
Steve Rugg
53 3100
Jim60 #1267750 06/01/2018 2:23 AM
Jim60 #1267770 06/01/2018 12:12 PM
On the road again
On the road again
Thanks, I didn't want to damage it or the steering wheel......
