| | | Forums66 Topics128,070 Posts1,055,892 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 76 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 76 | 1966 C-10 Short Step 250 Powerglide — I’m reassembling my truck after a year at the paint shop (long story). The backup lights worked before the tear down and now after reassembly are not working. I’ve looked at the shop manuals and with 1966 being the first year with backup lights, I’m not finding a lot of information. The light green wire leads to the back of the truck where there is a connector to tie the lights on both sides together. I have no power there. My questions are:
1. What fuse provides the power / or does the power come through the neutral safety switch? 2. Does the power supply wire go through the firewall immediately below the connector for all the other rear lights? 3. Is there a methodology to test the neutral safety switch / backup switch? 4. Can anyone direct me to a wiring diagram of the backup light circuit?
Any other help you can provide would be greatly appreciated.
| | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I cant answer your specific questions, but ensure you have a good ground back there. That is the first and easiest thing to check. New paint could compromise the ground between the fixtures and the bed or frame. | | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | Since the 66 wiring diagram doesn't show it, have a look at the 67 wiring diagram. 67 wiring diagram
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jul 2009 Posts: 76 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 76 | Thanks for the help. Here is what I have learned. I am still not certain what fuse the power is linked to but it does pass through the neutral safety switch. The power into the switch wire is dark green - power to the rear lamps is light green.. The power does indeed go through the firewall just above and slightly to the right of the gas pedal - and just below where the tail and directional lights pass through. For me, I removed the neutral safety switch and found it to be broken - so a new one is coming. Finally, I'll take a look at the 1967 wiring diagram and see if that is helpful. I did think of the "good ground" issue and have run additional ground wires from the back up lamp housings to the frame to assure a good contact. As soon as I get the new switch, and some housing gaskets I think I'll have this whipped... | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Good to go with the ground. I am not smart on much but I have learned that lesson. | | |
