5 members (baldeagle, Mike Roache, Gdads51, Hotrod Lincoln, Steelonsteel), 90 guests, and 2 robots.
Topics128,088
Posts1,055,993
Members48,430
#1266968 05/25/2018 1:35 PM
1966 C-10 Short Step 250 Powerglide — I’m reassembling my truck after a year at the paint shop (long story). The backup lights worked before the tear down and now after reassembly are not working.
I’ve looked at the shop manuals and with 1966 being the first year with backup lights, I’m not finding a lot of information. The light green wire leads to the back of the truck where there is a connector to tie the lights on both sides together. I have no power there. My questions are:
1. What fuse provides the power / or does the power come through the neutral safety switch?
2. Does the power supply wire go through the firewall immediately below the connector for all the other rear lights?
3. Is there a methodology to test the neutral safety switch / backup switch?
4. Can anyone direct me to a wiring diagram of the backup light circuit?
Any other help you can provide would be greatly appreciated.
I cant answer your specific questions, but ensure you have a good ground back there. That is the first and easiest thing to check. New paint could compromise the ground between the fixtures and the bed or frame.
~ HB
1962 Chevrolet C10
1962 Suburban
Insomniac
Insomniac
Since the 66 wiring diagram doesn't show it, have a look at the 67 wiring diagram.
67 wiring diagram
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thanks for the help. Here is what I have learned. I am still not certain what fuse the power is linked to but it does pass through the neutral safety switch. The power into the switch wire is dark green - power to the rear lamps is light green.. The power does indeed go through the firewall just above and slightly to the right of the gas pedal - and just below where the tail and directional lights pass through. For me, I removed the neutral safety switch and found it to be broken - so a new one is coming. Finally, I'll take a look at the 1967 wiring diagram and see if that is helpful. I did think of the "good ground" issue and have run additional ground wires from the back up lamp housings to the frame to assure a good contact. As soon as I get the new switch, and some housing gaskets I think I'll have this whipped...
Good to go with the ground. I am not smart on much but I have learned that lesson.
~ HB
1962 Chevrolet C10
1962 Suburban
