1 members (Hotrod Lincoln), 88 guests, and 5 robots.
Topics128,014
Posts1,055,325
Members48,419
#1267301 05/28/2018 11:49 AM
Is there such a tire as a 225/70/22.5? I can find chains for them but I cant find a supplier for the actual tire.
Id like to try and find some if they do actually exists as they are the same diameter as a 7.00 x20
Any help is appreciated
Digga1111 #1267321 05/28/2018 3:18 PM
The wheel is different though, do you have 22.5” wheels for the truck?
Depending on the truck you may do fine with a little taller tire, for example 9r22.5 tires fill up the fenders and look ok on a 48-54 two ton, on 22.5” wheels.
1952 Chevrolet 3800 pickup
---All pictures---
Digga1111 #1267418 05/29/2018 8:30 AM
Hey Grigg,
Iam looking at a set of 22.5 alcoas part no 873607. they are a 7.5 x 22.5. was going to get a set of adaptors made. My initial investigations found a 225/70/22.5 which is perfect to replace the 7.00x 20 on the front and 255/70/22.5 on the rear which would be a good replacement for the 7.50x20 rears. the 255/70/22.5 rears are no problem but I went searching for the 225/70/22.5 for the front and now I cant seem to find any suppliers. I was under the impression it was a tyre that was used a lot in RVs. Now iam not sure if they ever existed
Digga1111 #1267421 05/29/2018 11:36 AM
What year and model truck?
You can probably use same size front and rear, and probably fit larger than stock. Although a 7.5” wheel is getting a little wide for these old trucks, 6” rim and tires that fit a 6” rim might fit under the fenders better.
Won’t be original anyhow, so as long as the tires and wheels fit you’re good to go.
---All pictures---
Digga1111 #1267485 05/30/2018 12:51 AM
I just put 255/70R22.5's on the back of my '58. I can measure them if you would like.
BaconFarms
1948 GMC 2 Ton
1958 GMC 370-8
1965 GMC 5000
1970 Chevrolet C50
Digga1111 #1267492 05/30/2018 1:36 AM
I too was having a hard time for fronts, but finally went with a 235/80R22.5 front runners, they are a little taller than the backs, but fill the fender and look good.
Very good tires, but expensive. I bought used, like new, for $410 for the pair at an equipment auction.
I can measure both the fronts and the rears tomorrow or the next day an get back.
BaconFarms
1948 GMC 2 Ton
1958 GMC 370-8
1965 GMC 5000
1970 Chevrolet C50
Digga1111 #1268081 06/04/2018 12:13 PM
They look good. are there any clearance issues with the 235 on the front at full lock?
I will be fitting to a 43 chev truck
Digga1111 #1268082 06/04/2018 12:37 PM
A 43 model truck will fit tires differently than the later models, not a good comparison.
---All pictures---
Digga1111 #1269045 06/14/2018 1:01 PM
Hey Grigg,
I've been looking around a few forums at a few things and this Grigg fella comes up a fair bit. Was looking at a Diesel engine swap site last night and was looking through Griggs photo album of an old chev truck. Hold with a 6v53 Detroit. Any one you know?
