1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Anyone have a good source for these? Just put LEDs in the rear taillights/turn signals on my 49 3100. Searched forums but didn't see anything recent.
Ed
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Ed, Here are 6v LED flashers (it looks like they might be "ground sensitive"). I do not have first-hand experience with any of them. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Positive ground 6 volt? Look at Amazon âBV535â. Check before installation. I ordered several and one was wired incorrectly. Was real cheesy off shore stuff. A load resistor or regular bulb somewhere will be required.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | LED flasher - BV535? Type: Thermal Pilot Circuit: Yes Prongs: 3 LED Compatible: NoFor POSITIVE GROUND Vehicles only Here is a 6v negative ground LED flasher.Is the original poster looking for a positive ground 6v LED flasher? "my 49 3100" 6v negative ground | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Before we beat this to death if would be wise to wait till the original poster tells us he has a positive ground system or not.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "my 49 3100" would be 6v negative ground, unless it was changed to be like a GMC? | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Yes my 3100 is negative ground. Thanks for all the inputs so far.
Ed
