5 members (Shaffer's1950, Wayne67vert, Hotrod Lincoln, ‘37ChevyPU, Hanks custodian), 130 guests, and 1 robot.
Topics128,139
Posts1,056,454
Members48,441
Anyone have an idea where to get the O ring or rubber washer that goes between the lid and the center hold down bolt on a 59 AC type oil filter cannister? My original finally gave up the ghost. I've put a hose washer and a 9/16" flat washer on top of that. On idle and about 35# pressure it's OK but at speed and 45# it leaks. When I tighten it down more, the washer flattens out past the steel flat washer.
If I use a modern remote spin on filter, I'm assuming I should use the stock size hoses to keep the pressure up. Am I thinking right?
Thanks for your help guys!
web page
I know you believe you understand what you think I said, but I'm not sure that you realize that what you heard is not what I meant!
Riding in the Passing Lane
Is this a 6 or 8. Possibly a drain plug gasket
would work.
1972 Chevy c10 Cheyenne Super
Just went to Lowes and got a 1/2" copper washer, snugged it down real good and.... No leaks even at speed.
It may not be correct, but at least I'm on the road 'till I get the right stuff.
BTY, it's a 235 stovebolt with the '59 AC oil filter canister.
