Anyone have an idea where to get the O ring or rubber washer that goes between the lid and the center hold down bolt on a 59 AC type oil filter cannister? My original finally gave up the ghost. I've put a hose washer and a 9/16" flat washer on top of that. On idle and about 35# pressure it's OK but at speed and 45# it leaks. When I tighten it down more, the washer flattens out past the steel flat washer.
If I use a modern remote spin on filter, I'm assuming I should use the stock size hoses to keep the pressure up. Am I thinking right?
Thanks for your help guys!
web page
