2 members (jmoore, Phak1), 85 guests, and 4 robots.
Topics128,184
Posts1,057,270
Members48,467
1 Offline
anyone ever resleeved a straight axle , mine are out of round , i checked 1 place locally he wants $900.00 to do both sides this seems a little high , how hard is it to do ? 1pete1
Is a 0.010” oversize kingpin kit available? Will 0.010” correct the issue?
Otherwise you could bore oversize and install a steel sleeve but this would be more trouble and risk than finding a replacement axle in my opinion. Sleeves in the axle are probably not universally recommended, but I’ve seen it done.
•1952 Chevrolet 3800 pickup
---All pictures---
On my 1 Ton I had the axle bored and hardened sleeves installed. iIt has been just fine for 10 years and 40K miles. It has a standard bore now.
1951 1 Ton Completed
' Offline
Pete , You need to find a place like this .
https://www.dentoni.com/steer-axle-rebore
http://drivetrainservice.com/steer-axles/
http://www.precisionaxle.com/Services.html
https://www.axlesurgeonseattle.com/services.html
You can have your axle re-bored & sleeved right back to standard size .
Finding a standard size king pin kit should be pretty easy .
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
