3 members (Gray_Ghost, tesa, Johnny N), 88 guests, and 1 robot.
Topics128,076
Posts1,055,924
Members48,430
https://photos.app.goo.gl/g43OpGR7jhUFjmU02
What is this line coming out of the manifold below the carb that is bent back toward the firewall and cut off.
1941 1.5 ton 235
Does it still have the vacuum wiper motor? How about a vacuum operated 2 speed axle. That might explain the line out of the intake.
Wiper motor is missing. Mechanical 2spd axle
Sir Searchalot
Sir Searchalot
Looks like an early PCV system that went to the draft tube/crankcase tube.
I vote vacuum port/line.
Have you taken the fitting out to inspect it?
If yes, is it an open port (no internal valve)?
No I haven't taken that apart.
Fixer of Things I Probably Broke
That's where my vacuum windshield wiper motor taps in on my '53 235. (Soon to be where my power brake booster taps in.)
1953 Chevy 3100 Frankentruck with 235 and mostly original bits.
Thanks for all the replies. With your input and the interweb a wiper motor seems likely.
I also think wiper motor. Plug it and drive on.......
I love 60 year old jigsaw puzzles!
Ron - - Dusty53
1954 Chevy 3604
That is where my vacuum wiper motor was attached.
