4 members (RLB, Shaffer's1950, Otto Skorzeny, Mr Crosswrench), 121 guests, and 3 robots.
Topics128,132
Posts1,056,391
Members48,441
#1266527 05/21/2018 2:59 AM
So I have a stock 59 Apache with a new rebuilt 235 sm420 tranny with 390 gears ! But ??
I want (need ) overdrive gotta cruise at 65 , so I got me a t5 transmission , with a 4.03 first, 237.1 second ,1.49 third , 1 to 1 forth , and my Hybrid 5th gear at .72 .
my sm420 is 7.1 357.1 1.70 1 to 1
My ????? what will it be like starting from a stop light ??
I do use the 7.1 in stop and go traffic and i like it ! Your 2cents please
59 chevy apache fleetside
2007 dodge diesel
84 toyota 4 runner, v8,propane power
Starting out in 1st gear you'll hardly need to ride the clutch or give it much gas. You will be shifting in to 2nd very quickly.
V
VEW Offline
V Offline
sm420 357.1
Seems like it will be very similar to you starting out in second with your existing 420
~ Victor
1957 3100 - moved on
I"m hoping I will be able to start out with the t5 in second gear 237.1 ???? Too high of gears from a dead stop ?
guess I will find out ?
2007 dodge diesel
2007 dodge diesel
You will use first gear and get used to it pretty quickly. Starting in second gear will be an option when on the level. I doubt you’ll have any issues unless you are loaded down.
I've got a 3.73:1 rear end and 27.5" tall tires and first gear with the T5 is only slightly low- no different than a Jeep Wrangler I used to drive.
~ Dave
Thanks gentlemen !!! I will update you soon with my results ,,
Big thank you too , Lugnutz I have read your t5 info page at least 20 times AWESOME INFO
2007 dodge diesel
sm420 is great for going slow , Pow Wow day parade ! I 'm thinking I might miss that low gear ?
I hope the pics show up ???
2007 dodge diesel
It won't be a granny gear in first gear with the 3.90. It will be very driveable non the less.
